Having trouble starting a recording using the Vaapi + ffmpeg on my integrated graphics.
Apoletestry
At the moment I only plan on recording.
I have recently only been able to record using x264 encoder, but the quality and performance is subpar even for 720/ 768p (1366 x 768 is my laptops screen resolution).
When the Vaapi was working, my computer was running pretty good, and the quality of the recording was also good as well, I 'was' in Heaven, it seemed.
But it worked only twice or so and never again, i have no idea what causes this error, making the vaapi encoding sees to function entirely on both the integrated an the discrete ("""dedicated""") graphics.
The Error:
Failed to start recording
Starting the output failed. Please check the log for details.
Note: If you are using the NVENC or AMD encoders, make sure your video drivers are up to date.
Most likely it is a graphics driver issue, I don't know about the ffmpeg or Vaapi version though.
Maybe resetting ALL of the graphics drivers back default when I first installed Ubuntu on here, might fix.... Something???
  • 2021-12-21 11-53-07.txt
Tuna
Not sure if valid for this particular model, but some Intel cards require the "i965-va-driver-shaders" driver package instead of the regular "i965-va-driver".
Apoletestry
No, that didn't seem to do anything. I can't seen to find a good repo or package for the integrated graphics.
