Help with MOVE Transition plugin.
Barryb64
Hello there,
My name is Barry and I recently installed the latest version of OBS Studio 31.1.2 (64 bit) for Windows 11. I will start by saying that I am impressed by how much has changed for the better. My last dealing with OBS Studio was in 2022. I came back to it with a system capable of handling this program. Here's my issue.
I created a Scene called Intro. I just wanted to create an animated scene where my intro (containing a landscape photo and my channel's logo) to fade in, stay for about a second or two and fade out move on to the next scene with my webcam. It was suggested that I make use of the Move Transition plugin. I am likely using it wrong; however I can't seem to get it working.
I'm using Move Transition 3.1.5 I was trying to use it on a source image in the Intro Scene and it says that it can only be applied to Scene and Group. Can some please help me. Thanks. Was there a separate plugin called Move Source??
alvarez97
Hello Barry, from what I think you want to accomplish, you need to use the stinger transition which is already in OBS. You going to need to add a video of your intro though for it to work.
