How to choose downscale filter in OBS 29 when using the same out base and output resolution
GaetanTTV
Hello Guys !
How can I choose the downscale filter in OBS 29 when using the same Base and Output resolution in the Video tab ?
please, do not just say "there are no filter applied", and bear with me .. :)
I am asking this because I want to record in 1080p 60 FPS , and stream to Twitch at 720p 60 FPS
Until now, I have streamed to Twitch to 1080p60fps but after some research it seems the 6000 bitrate would not be sufficient and would cause some issues, therefore I want to downscale the stream to 720p60fps, but still record and use the replay buffer at 1080p60fps
Basically, I want to make sure to use bicubic downscale filter, while downscale the stream output only.
Here are a couple other forum threads that led me to this conclusion, in case this may help:
- https://obsproject.com/forum/threads/936p-vs-1080p.157676/
- https://obsproject.com/forum/threads/which-downscale-filter-to-use.125517/
My spec:
OBS 29.1.3 64 bit for Apple Silicon
Mac Mini M2 Pro
Mac OS 14.0 Sonoma
so I have this in settings :
• VIDEO TAB
base resolution : 1920 x 1080​
Output resolution : 1920 x 1080​
Downscale filter : i can't choose anything I have a message : "resolution match, no downscaling required"
FPS : 60​
• OUTPUT TAB
STREAMING
audio encoder : Core Audio AAC​
Video encoder : Apple VT H264 hardware encoder​
Recale Output : CHECKED | 1280 x 720​
Encoder settings
Rate control : CBR​
Bitrate : 5000 Kbps​
Keyframe int. : 2s​
Profile : high​
B-frame = yes​
RECORDING
Format : fragmented MP4​
Video Encoder : Apple VT HEVC Hardware Encoder​
Audio Encoder : CoreAudio AAC​
Rescale Output : UN-CHECKED | 1920 x 1080​
Encoder Settings
Rate control : CBR​
Bitrate : 10000 Kbps​
Keyframe int. : 1s​
Profile : main​
B-frame = yes​
So my stream is indeed going in 720p and my recordings are in 1080p , but I could not find how to select which downscale filter to apply to my streaming output...
Hope someone can help !
Thanks in advance !
EDIT: if I placed this post in the wrong section , please move my post to the appropriate section , thank you !
