Question / Help I keep getting this pop up Help
hawkrmb3619
when I click start stream i keep getting this pop up and i dont know why plz help
Krazy
Town drunk
Then you need to double/triple check that your stream key was put in accurately. You may also need to reset your stream key, also done at http://www.twitch.tv/broadcast
edit: As a side note, you can check your stream key in %appdata%\OBS\Profiles and open the txt file of the profile you want to use. Scroll towards the bottom, under the [Publish] section and look for "PlayPath=" and that will be your stream key. That's probably the easiest way to double check you put it in correctly
Xpariah
I too am getting this error. First time ever. I have streamed fine (even yesterday.) I reset my key twice and copied it. There is no error in inputting the correct information.
Any help would be appreciated.
