Bug Report igrabber component cables to USB crash
thorium90
my OBS crashed consistently when using igrabber hardware/software to capture my nintendo gamecube. if I started streaming or previewed stream, OBS would immediately crash. I made sure that all of my hardware was working fine, so I am reasonably sure it is OBS that is causing the crash. please help, thank you for your time!
(crash report/log attached)
  • 2013-09-02-1820-42.log
  • OBSCrashLog2013-09-03_2.txt
Lain
Lain
I'm not entirely sure why a device would fail there -- it typically means that the data it's sending to OBS is invalid or incomplete. I'd probably have to have the device to know for sure. I do have a gamecube/wii so maybe I might buy this device or something.
Also, check for newer drivers for the device.
