I'm having a lot of stutters and choppiness during recordings
JFK
Hi there, I was just wondering if I could get some help on a problem that arose. When I try to record on obs it stutters a lot (not in-game at all) and I can't find a solution. Running as administrator helps in the preview, but it also lowers my frames in game and still is choppy in the actual recording itself.
Here is my latest Log: 2020-08-05 20-16-56.txt
And here is my pc build: https://pcpartpicker.com/list/dYYhf9
Thanks!
  • 2020-08-05 20-16-56.txt
WizardCM
Community Helper
20:37:50.464: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 778 (26.1%)
You're overloading your graphics card. You can verify this in Task Manager -> Performance -> GPU -> 3D
To fix this, run OBS as Administrator, or lower your in-game settings.
JFK
I tried a few tests by running obs as administrator and lowering the settings by a lot and I saw no difference, but then I opened task manager on my second monitor and saw that I was only using tops of %46 of my card, and same with the cpu.
