input lag when opening obs
fenoncobra
good afternoon friend how are you with a problem when i open OBS and i will play euro truck simulator 2 or american truck simulator i have frametime autos and when i close OBS the game is normal. give a helping hand guys
https://obsproject.com/logs/6d5oSyUgAMemgO5t
,config
Windows 10 Pro
MSI Z97 MPOWER MAX AC motherboard
Intel Core i7-4790K 4.40GHz processor
CORSAIR VENGEANCE PRO SERIES MEMORY 16GB (2X8) 2400MHZ DDR3
ZOTAC GeForce® GTX 1080 AMP Extreme Video Card
SOURCE Corsair Ax1200 80plus Gold
SSD CORSAIR FORCE LE 120GB
Kingston A400 SSD, 240GB
LG IPS LED Monitor 23 Inch X3
samsung 32 inch tv
WebCam: Logitech C920 Pro HD
WebCam: Microsoft lifecam hd 3000
BM800 Microphone
  • 2020-10-02 15-52-56.txt
qhobbes
1. Record to FLV or MKV. If you record to MP4 or MOV and the recording is interrupted, the file will be corrupted and unrecoverable.
If you require MP4 files for some other purpose like editing, remux them afterwards by selecting File > Remux Recordings in the main OBS Studio window or enable Auto remux in the advanced settings.
2. Your GPU is maxed out and OBS can't render scenes fast enough. Running a game without vertical sync or a frame rate limiter will frequently cause performance issues with OBS because your GPU will be maxed out. OBS requires a little GPU to render your scene.
Enable Vsync or set a reasonable frame rate limit (60 in your case) that your GPU can handle without hitting 100% usage.
If that's not enough you may also need to turn down some of the video quality options in the game. If you are experiencing issues in general while using OBS, your GPU may be overloaded for the settings you are trying to use.
Please check our guide for ideas why this may be happening, and steps you can take to correct it: GPU Overload Issues.
Browser sources are performance killers
Web browsers are amazingly complex feats of software engineering. They render text, images, 2D graphics, 3D graphics, and animations, and they can play audio, video, and games! However, they are also pretty heavy resource hogs. The same goes for the Browser Source, which is often used to display stream chats, custom animations, overlays, and many other things. Lots of browser sources in a scene (or scene collection) can end up using a lot of system resources.
Try to reduce the number of browser sources that you use. You have 4 in 1 scene. If you have static assets (non-animated overlays), try using other source types for those things (like Image Source). If you need to play a video or audio file, try the Media Source or VLC Source.
fenoncobra
already I enabled Vsync at 60FPS I keep an eye on it and my GPU does not exceed 70% of usage and my CPU does not exceed 30% of usage on the sources I used normal without problems. just opening OBS without recording or Livestream the game is with frametime auto I don't know what I can do anymore
D
Deleted member 121471
Since you are recording, use "CQP" Rate Control set somewhere between 16 and 20 (lower values = higher quality and larger filesize) and "Quality" preset. Also, turn on "Game Mode", under Windows 10 settings, if it's not so already.
Make sure you do not have any overlays active, such as GeForce Experience.
fenoncobra
I will try the "CQP"
