Input Overlay not loading into sources correctly (Mint)
ggkazii
I've just installed Input Overlay via the official .deb package from the project's GitHub page and it is not properly loading into my Sources list. I have examined the log and found something somewhat peculiar.
17:59:02.908: os_dlopen(/usr//lib/x86_64-linux-gnu/obs-plugins/input-overlay.so->/usr//lib/x86_64-linux-gnu/obs-plugins/input-overlay.so): libQt6Widgets.so.6: cannot open shared object file: No such file or directory 17:59:02.908: 17:59:02.908: Module '/usr//lib/x86_64-linux-gnu/obs-plugins/input-overlay.so' not loaded
Obviously, the directory "/usr//lib" does not exist, and I've checked the *correct* directory without the extra slash and have confirmed that input-overlay.so is there, so it just seems like for some reason the program is pointing to a non-existing directory to look for it. How can I get it to point in the right direction, and if this isn't the problem, what could I do to fix it? Attached full log.
  • 2022-12-08 17-59-02.txt
[SG]Muwa
I have same error, but without // in snap package. Kubuntu 23.04
  • 2023-08-07 17:47:52 +0400 obs-studio input-overlay.log
[SG]Muwa
I installed version from instruction https://ubuntuhandbook.org/index.php/2018/03/install-obs-studio-21-1-in-ubuntu-18-0416-04/ (sudo add-apt-repository ppa:obsproject/obs-studio, remove snap package, install via apt) and install input-overlay last version (https://github.com/univrsal/input-overlay/releases/tag/v5.0.4) and it's work because package from ppa:obsproject/obs-studio also install qt6
