Is he using Draw or can I do with Draw?
munchman
Hi all, hope you can help as Im a bit of an OBS newcomer. I am trying to achieve a similar result to this guitar teacher Tim using OBS and Draw I think. Link to reel
For the guitar neck think he is using OBS and screen capture? (not sure if its screen capture?) to capture the midi guitar neck, flipped 90 degrees...so far so good.
Question: 15 secs in you see him reach down and I'm certain that he's using Draw to put the coloured annotations on (not the dynamic ones, thats from the midi guitar as he plays) and he seems to switch backwards and forwards at times to remove, re-add the dots.
Any ideas how I would set this up? Is he just creating scenes, one with no annotation, some with annotations.. I'm a little uncertain how to achieve this properly and a noob atm
Many thanks and I hope thsi is ok to ask here
Thanks, Ben
