FireEmblem6
So, I have been banging my head against the wall for a while with this issue. I have tried nearly everything outside of burning it all to the ground.
Here is the issue. While using the Elgato to stream/record anything that has a cut scene, the recording skips at the beginning, and end of these scenes (sometimes for a few moments after) While using the Elgato program to record alone, there is no skipping. Recording the game on the gaming machine using obs causes no skippage. It only happens while using the Elgato to stream through obs. It doesn't matter what system is running obs. I have tried it with three different systems (2 gaming one laptop) and got the same results every time. I have tried changing nearly all of the settings in obs. The closest I got was changing the custom buffer size up to 15,000 in which only caused one skip.
I really am not sure what I can do to fix this issue. It works great while there are no cut scenes going on, and have even tested several high action games with no skippage. Just with cutscenes.
I believe this code is set back to my wife's default streaming settings. I am hoping someone can help me with this!
17:54:34: CLR host plugin strings not found, dynamically loading 4 strings
17:54:34: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
17:54:34: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
17:54:34: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
17:54:34: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
17:54:34: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
17:54:35: CLRHost:: Could not find/load browser settings at location C:\Users\Lappy\AppData\Roaming\OBS\pluginData\browser.json
17:54:35: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\Lappy\AppData\Roaming\OBS\pluginData\browser.json'.
17:54:35: File name: 'C:\Users\Lappy\AppData\Roaming\OBS\pluginData\browser.json'
17:54:35: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
17:54:35: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
17:54:35: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
17:54:35: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
17:54:35: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
17:55:58: Open Broadcaster Software v0.657b - 64bit ( ^ω^)
17:55:58: -------------------------------
17:55:58: CPU Name: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
17:55:58: CPU Speed: 2394MHz
17:55:58: Physical Memory: 8108MB Total, 6729MB Free
17:55:58: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
17:55:58: monitor 1: pos={0, 0}, size={1600, 900}
17:55:58: Windows Version: 10.0 Build 10586 (revision 0)
17:55:58: Aero is Enabled
17:55:58: OBS Modules:
17:55:58: Base Address Module
17:55:58: 00000000F7680000 OBS.exe
17:55:58: 000000004BB80000 OBSApi.dll
17:55:58: 0000000061990000 CLRHostPlugin.dll
17:55:58: 000000005E4E0000 DShowPlugin.dll
17:55:58: 000000004D860000 GraphicsCapture.dll
17:55:58: 0000000061960000 NoiseGate.dll
17:55:58: 0000000057020000 PSVPlugin.dll
17:55:58: 0000000054C30000 scenesw.dll
17:55:58: ------------------------------------------
17:55:58: Adapter 1
17:55:58: Video Adapter: NVIDIA GeForce GT 755M
17:55:58: Video Adapter Dedicated Video Memory: 2089680896
17:55:58: Video Adapter Shared System Memory: 4251113472
17:55:58: Video Adapter Output 1: pos={0, 0}, size={1600, 900}, attached=true
17:55:58: Adapter 2
17:55:58: Video Adapter: Intel(R) HD Graphics 4600
17:55:58: Video Adapter Dedicated Video Memory: 117964800
17:55:58: =====Stream Start: 2016-03-28, 17:55:58===============================================
17:55:58: Multithreaded optimizations: On
17:55:58: Base resolution: 1280x720
17:55:58: Output resolution: 1280x720
17:55:58: Loading up D3D10 on NVIDIA GeForce GT 755M (Adapter 1)...
17:55:58: Audio Format: 48000 Hz
17:55:58: Audio Channels: 2 Ch
17:55:58: Playback device Default
17:55:58: Using desktop audio input: Speakers (Realtek High Definition Audio)
17:55:58: Global Audio time adjust: 0
17:55:58: Audio Encoding: AAC
17:55:58: bitrate: 160
17:55:58: device: Elgato Game Capture HD,
17:55:58: device id {39F50F4C-99E1-464A-B6F9-D605B4FB5918},
17:55:58: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 166666-166666
17:55:58: use buffering: true - 0, fourCC: 'UYVY'
17:55:58:
17:55:58: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
17:56:01: Elgato Game Capture: force buffering with 1 msec
17:56:02: Using directshow input
17:56:04: Scene buffering time set to 700
17:56:04: ------------------------------------------
17:56:04: Video Encoding: x264
17:56:04: fps: 60
17:56:04: width: 1280, height: 720
17:56:04: preset: veryfast
17:56:04: profile: main
17:56:04: keyint: 120
17:56:04: CBR: yes
17:56:04: CFR: yes
17:56:04: max bitrate: 2100
17:56:04: buffer size: 2100
17:57:42: FlushBufferedVideo: Flushing 21 packets over 333 ms
17:57:42: Total frames encoded: 5847, total frames duplicated: 4 (0.07%)
17:57:42: Total frames rendered: 5876, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
17:57:45:
17:57:45: Profiler time results:
17:57:45:
17:57:45: ==============================================================
17:57:45: video thread frame - [100%] [avg time: 1.486 ms] [children: 64.3%] [unaccounted: 35.7%]
17:57:45: | scene->Preprocess - [55.8%] [avg time: 0.829 ms]
17:57:45: | GPU download and conversion - [8.55%] [avg time: 0.127 ms] [children: 8.08%] [unaccounted: 0.471%]
17:57:45: | | flush - [7.54%] [avg time: 0.112 ms]
17:57:45: | | CopyResource - [0.404%] [avg time: 0.006 ms]
17:57:45: | | conversion to 4:2:0 - [0.135%] [avg time: 0.002 ms]
17:57:45: Convert444Threads - [100%] [avg time: 0.528 ms] [children: 99.4%] [unaccounted: 0.568%]
17:57:45: | Convert444toNV12 - [99.4%] [avg time: 0.525 ms]
17:57:45: encoder thread frame - [100%] [avg time: 0.966 ms] [children: 4.66%] [unaccounted: 95.3%]
17:57:45: | sending stuff out - [4.66%] [avg time: 0.045 ms]
17:57:45:
17:57:45:
17:57:45: Profiler CPU results:
17:57:45:
17:57:45: video thread frame - [cpu time: avg 1.05 ms, total 6171.88 ms] [avg calls per frame: 1]
17:57:45: | scene->Preprocess - [cpu time: avg 0.59 ms, total 3468.75 ms] [avg calls per frame: 1]
17:57:45: | GPU download and conversion - [cpu time: avg 0.039 ms, total 234.375 ms] [avg calls per frame: 1]
17:57:45: | | flush - [cpu time: avg 0.029 ms, total 171.875 ms] [avg calls per frame: 1]
17:57:45: | | CopyResource - [cpu time: avg 0.002 ms, total 15.625 ms] [avg calls per frame: 1]
17:57:45: | | conversion to 4:2:0 - [cpu time: avg 0.002 ms, total 15.625 ms] [avg calls per frame: 1]
17:57:45: Convert444Threads - [cpu time: avg 0.379 ms, total 4421.88 ms] [avg calls per frame: 2]
17:57:45: | Convert444toNV12 - [cpu time: avg 0.376 ms, total 4390.63 ms] [avg calls per frame: 2]
17:57:45: encoder thread frame - [cpu time: avg 0.716 ms, total 4171.88 ms] [avg calls per frame: 1]
17:57:45: | sending stuff out - [cpu time: avg 0.026 ms, total 156.25 ms] [avg calls per frame: 1]
17:57:45:
17:57:45: =====Stream End: 2016-03-28, 17:57:45=================================================
