Keep Disconnecting and Reconnecting from Facebook
TheUniversalist
Out of the blue, I keep disconnecting and reconnecting with my Facebook gaming page. I was fine up until Saturday with no issues. I provided my log file below for some guidance. Is this an ISP issue or Facebook issue? I have exhausted all other options in making sure network and router firmware is up to date.
  • 2022-01-18 18-54-51.txt
Lawrence_SoCal
1. don't record to MP4.. just don't.. lots of explanations here and elsewhere as to why, so I won't repeat. This will be my only reply if you insist on sticking with recording to MP4
2. Your logs has lots of
21:31:24.672: obs-browser: Access to XMLHttpRequest at 'https://api.streamelements.com/kappa/v2/widgets/6124ec171bccd0520924dae9/facebook-chat' from origin 'https://streamelements.com' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource. (source: https://streamelements.com/overlay/...hZHK_sACc-LpE-x4orPTe2t9EBtR_EI6tiu3_EivUbL:0)​
so maybe the PoS plugin causing your issue? I streamed to Facebook on Sunday for over an hour with no issue
3. An OBS log does not (and shouldn't) do real-time monitoring of your Operating System, local network or ISP.
From the disconnect message in the OBS log, I'd guess either a network issue (could be LAN or ISP), or that $%@!# plugin interfering
