Question / Help League of Legends FPS drop with OBS
DrylipJohn
Hello folks,
So everything was fine till recently. I am getting FPS drops in game and its getting frustrating because it all used to work perfectly normal. I ve tried various settings on OBS and still nothing.
System Specs :
CPU : Intel i7 4790k 4.00Ghz
RAM : 24GB Ballistix
PSU : Corsair Cx750
Graphics : Nvidia MSI 980ti 6GB Ram DDR5
HD : Samsung SSD 240GB
Honestly i think its sad that i have to adjust my settings with my current rig but, attached is some screen shots of my settings.
http://tinypic.com/r/2mqut5i/9
http://tinypic.com/r/1xzb0x/9
yongyung
Okay so first of all, I'd recommend using OBS-Studio, as OBS classic has not been updated in ages and will never get any updates again except small bug fixes.
With that disclaimer out of the way, you want CBR for streaming. Using quality based encoding only makessense for local recording - if you're streaming, the overall transmission size doesn't matter, only the bandwidth. So, enable CBR and try again.
