Question / Help Logitech G25 Steering Wheel conflict
grester
Keeping it short, I've realized that my Logitech G25 Steering Wheel somehow conflicts with OBS.
When I start OBS the wheel so to say "crashes" and the power LED starts flashing meaning that some sort of an error has occurred and wheel is no longer active in stand by mode. OBS on the other hand stays fine without any problem. Has anyone else had similar problem? I've try search for "G25" in the forums but nothing came up, therefore I'm posting this so that the devs become aware of this hassle since it's not in the list of devices with issues. I've run the log analyser but nothing came up still I'm attaching a log file to this topic. I'm also running the latest drivers for the wheel. I've decided to post this problem here since it wasn't a problem specifically in OBS itself.
  • 2013-11-17-1756-43.log
grester
UPDATE: So after I rebooted PC some weird driver error with steering wheel made it unrecognisable, i had to replug for the game to detect. That time while I was streaming the wheel had the same problem again, kinda made me mad as I thought problem was solved. I've repluged wheel and retried, this time for some reason the problem didn't occur. As a test before I start stream I have it stay in preview mode for a few minutes as in the past even in preview the wheel would crash. Along with the preview test I've also started stream with mic muted, somehow the wheel didn't crash this time. I don't know if problem is in fact starting stream with mic unmuted or was the issue I had when PC started. Either way I'm still trying to investigate better this issue so it can more easily be understood what's causing this problem thus fixing it.
Nihilius
I still have this issue in 2017 using my G27 steering wheel. It is driving me crazy as I can't stream nor record any meaningful footage of racing game since every few minutes my wheel crashes.
Is there really still no fix for this? :(
