Bug Report LoL game capture not always working
DitisGG
I just started streaming and i'm having some problems with the game capture mode. When i'm streaming DayZ everythings works fine, But when i'm streaming LoL the game capture doesn't always work.
I added a global source, game capture and added league. Sometimes it works, sometimes it doesn't. But when it works, it will be working as long as i don't shut off my computer. When i try to stream the next day, the game capture will not work. I have to try 10 times setting up a new gamecapture and most of the times it doesn't work. After trying 10 to 20 times, it will work again.
Is there anyone having the same problem? and does anyone know a solution for this problem?
  • 2014-01-28-0932-32.log
Lain
Lain
Are you trying to capture the lobby? LoL is a special case - you must use window/monitor capture on the lobby, and window capture or game capture on the in-game window. It's a bit frustrating to deal with but that's how they designed their game. It doesn't seem like you have multiple scenes set up or anything.
DitisGG
I dont have multiple scenes because i just reinstalled everything. Normally i use windowcapture for the lobby and game capture for the game. But the game capture mode isn't always working.
DitisGG
Today again, yesterday everything worked fine after reinstalling everything. Today i started OBS, and it didn't work, ill add another logg file.
  • 2014-01-29-1256-18.log
