Memory Leak
bitman
First time poster - I tried to use Mantis but I don't see a way to CREATE an issue (just view them) so I'll try here. I'm a long time OBS user, mainly used to do live streaming but on occasion I make recordings too. Impressive project, but you all know that already. I have a long time issue - the video source "hicks up" when you first start OBS. It doesn't use the settings of the video device. If you go to the properties of the video stream source, it jumps immediately to the settings and if you're lucky you can APPLY/OK and things will work. But most likely, OBS will freeze if you try to adjust anything and it takes a restart of OBS and everything works. So it's something transient.
I had Fedora34 dump the normal "stdout" to a terminal, and I what I see is a "Number of memory leaks: 2" (see attachment obsoutput.txt).
I see other warnings/errors but the memory leak seems to be closer than anything else to describe what I see.
$ rpm -q obs-studio
obs-studio-27.1.3-1.fc34.x86_64
$ obs --version
OBS Studio - 27.1.3 (linux)
If this is the wrong place for "issues" please let me know where to post them. It's a small thing, but if I can help making OBS better I'll be happy to do so by reporting and answer questions about what I see.
  • obsoutput.txt
