Question / Help MIRROR EFFECT problem
Rico714PR
ocns2bhpj
https://postimg.org/image/ocns2bhpj/
ocns2bhpj
every time I open the obs mirror in front another mirror effect happen ,obs studio too
can't upload the screen capture ,please help
Harold
Droste effect. It's not a problem, it's normal behavior of what you're telling the program to do.
Rico714PR
ok , how I make it go away , I follow every tutorial step by step , in video tutorial guy press preview and no droste ,I press preview droste effect , can't find nothing about this
Harold
You simply don't use display capture or at least don't have the OBS window open on the display you're capturing.
dodgepong
Administrator
Community Helper
You're capturing your screen, and OBS is on your screen, so OBS is capturing itself. I'm not really sure what you were expecting. If you minimize OBS or move it to another monitor, the effect will go away.
