Missing my recordings
hunterb
I've been using OBS flawlessly for a while now and the last two times I've tried to record something the video is not in my set output folder. I have the logs from those days and doing the math for counting the frames(at 60fps) I can see that it recorded them. The recording just disappeared and I have no clue where it went.
I just finished a full system search in my file explorer and they are nowhere to be found.
I appreciate and ideas.
  • 2022-10-05 19-35-32.txt
  • 2022-10-10 19-58-02.txt
.norman.
both logs indicate that you did not record. it shows that you started a stream but it doesn't show where you started a recording.
.norman.
there would be ==== Recording Start =============================================== in the logs if a recording were started.
