Question / Help My Audio is out of sync for some reason
PannulaLoL
Hey Guys! So I've been streaming for a couple months now and have never had this problem until last week. The audio doesnt match my lips and seems to play b4 my lips even move. I made a highlight of the problem to try to help you guys help me.
https://www.twitch.tv/pannulalol/v/81581963
  • 2016-08-03-1228-02.log
kill3rman1ac
ok found a minor fix. Under settings>audio set your mic sync offset to 1000. this should bring it pretty close if not spot on for the delay
Update: clear the mic sync offset and set it back to 0. under Advanced under the audio section check "force desktop audio to use timestamps as base audio time" Then under global audio sync offset, set that to 1000
