My obs crash, and i don't know why, can you help me?
Kinukii
i'm having some problems with obs, he crashed a lot, maybe on all my streams... it's been crashing for about 2 months and i don't know why.
By looking at the forums, i saw that there was crash files in the obs documents, here they are.
I found only 5, dont' know why there aren't more..
I thought the problem came from the streamelements plugin, so I uninstalled it, then I also uninstalled obs then reinstalled, without putting streamelements back, but nothing changed.
I hope someone will find where my problem comes from.
Thanks in advance.
PS : Sorry if my english is bad !
  • Crash 2023-03-27 15-19-45.txt
  • Crash 2023-03-27 17-21-00.txt
  • Crash 2023-04-24 22-48-24.txt
  • Crash 2023-05-08 09-23-12.txt
  • Crash 2023-05-12 08-32-52.txt
The crash is caused by streamelements plugin.
To fixit you must remove this plugin. Uninstall the plugin with the provided uninstaller for this plugin. Now go to %appdata%\obs-studio\ and delete all the leftover files the plugin left in there. Then uninstall OBS and reintall OBS in order to fix what was broken by this plugin.
Or contact them directly.
Kinukii
Ok, Thank you, i will try this !
