Question / Help Need help (old OBS), elgato game capture 60 hd S
dadi01
Hello guys,
i know that the "old" OBS isnt supported anymore but please have a look at my problem.
Yesterday my new Elgato HD60 S arrived and i started some test recordings with OBS.
But there is one problem. My recording is lagging. EVERYTIME. If i use NVENC or the H.264 its still lagging.
The same problem at GameCapture HD Software. My recording is badly lagging and unusable.
I changed the quality and the resolution and all other things to save performance but (and i changed the usb port, now i use a 3.1) but nothing worked at all.
Please help me :)
  • 2018-08-08-0918-03.log
Harold
Since you're having the problem with the elgato software, contact them for support on this issue.
As long as you're still using the old obs, you're on your own.
Harold
Again, if the stuttering is happening with the elgato software as well, then the problem you're having is not something we can help with.
