Question / Help No Mic/Desktop Audio when recording?
AbsolutelyAmel
I used to record often and have not done so in a while, although I did stream recently and all was fine!
When I tried to do some test recording today and I checked the recording it was either that my mic was heard but there was no desktop audio- I removed a filter i put on it was the other way around. One of the two was not working all of the sudden.
Yes, when recording the visual does tell me that it picks up the sound. I attatched the log file if anyone has an idea?
I have a Blue Yeti and usually record with my earbuds plugged into the microphone (So I can hear myself talking)
Which leads to the in and output for sound being the blue yeti (Desktop and Mic)
I have never had this issue before and It worked perfectly a week or so ago? What can I do?
  • 2020-01-19 13-25-41.txt
R1CH
13:25:48.174: [FFmpeg aac encoder: 'Track2'] bitrate: 160, channels: 2, channel_layout: 3
13:25:48.181: [FFmpeg aac encoder: 'Track3'] bitrate: 160, channels: 2, channel_layout: 3
You're most likely only listening to one of the tracks in your playback.
AbsolutelyAmel
How can i fix that? Thank you for your quick response!
R1CH
You will need to use an editor to merge all the tracks. If you didn't intend to use multi track recording, then go back to simple output mode.
AbsolutelyAmel
I intentionally did the multi audio track recording so i could adjust the volume etc later on in editing.
But my issue is that when i finish the video and view the raw file the desktop (game) audio is missing while i can hear myself on the mic just like usual.
It worked perfectly a while ago and i have not played with the settings ever since then so I don't understand what the issue is and how to fix it?
No media player will mix tracks for playback. It will always play back only one track at a time, and the track can be switched within the media player.
You seem to write 2 tracks to your video file, OBS tracks 2 and 3. Perhaps you additionally wrote OBS track 1 to the video in the past, which might perhaps contain a mixed version of the sources you write to track 2 and 3. In this case, track 1 can be used for quick preview in any media player and actual editing can take place with tracks 2 and 3.
