Question / Help Noise suppress filter on linux ?
quentin de Vial
I am on Ubuntu 16.4 and I got some trouble with noise sound. I check many posts but on the obs version I got 16.2 I don't have the noise suppress filter. I got the two other, gain and noise gate.
Is it normal ? Do you know an alternative to cut the noise sound ?
Thank you a lot :)
quentin de Vial
Thank you for your help. The first solution didn't change any thing really but the second one with echo-cancel gave me a better result.
Also if others got the same problem I found a way to improve the quality a lot by going on alsamixer and set all levels around 60. Now I have a pretty decent quality
