OBS closing itself as soon as opening
mrnotloc
Not sure what the issue is. I have tried uninstalling and reinstalling but I am getting nowhere. Just want to start fresh. I have attached a copy of my most recent logs to this post.
  • 2024-11-16 14-05-24.txt
qhobbes
Start with disabling HAGS while OBS is closed. The Hardware-accelerated GPU scheduling ("HAGS") feature in Windows is currently known to cause performance and capture issues with OBS, games and overlay tools. It's an experimental feature and we recommend disabling it via these instructions.
mrnotloc
Hmm. I turned it off but I am still unable to keep OBS open. It just opens then closes again immediately.
qhobbes
Follow the instructions below. Does this still happen?
Suslik V
Also, worth a look at more detail instructions how to delete plugins. Because some can be loaded not from OBS folders (OBS will look for directories specified by the OBS_PLUGINS_PATH and OBS_PLUGINS_DATA_PATH environment variables in attempt to load external plugins in addition to the default program's location). Example:
prgmitchell
I did previously yes.
okay, if you check your windows defender history you'll probably see that it has quarantined the streamlabs plugin which would cause this. you just need to fully uninstall the plugin, then uninstall OBS, then reinstall OBS if this is the issue.
mrnotloc
this actually fixed it for me. streamlabs-obs was messing up my setup and now it opens normally. thank you
