Bug Report OBS Crash (libx264-136.dll)
BossBrew
OBS has been crashing for me recently 10-15 minutes after I start streaming.I have had this issue for the past few days I haven't found a solution.
Here is the Crash Log and Log File. Attached is also the dump file of the crash.
This crash appears to have occured in the 'c:\program files (x86)\obs\libx264-136.dll' module.
Fault address: 6578BF41 (c:\program files (x86)\obs\libx264-136.dll)
OBS version: Open Broadcaster Software v0.582b
Windows version: 6.2 (Build 9200)
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Crashing thread stack trace:
Stack    EIP      Arg0     Arg1     Arg2     Arg3     Address
0F11F1E0 6578BF41 00000010 1B67EEC4 000002C0 FFFFFFEF libx264-136.dll!0x6578bf41
0F11F1E4 09D98380 1B67EEC4 000002C0 FFFFFFEF FFFFFFF6 <unknown>!0x9d98380
A minidump was saved to C:\Users\Abraxas\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-11-27_5.dmp.
List of loaded modules:
Base Address      Module
23:36:03: Open Broadcaster Software v0.582b - 32bit (´・ω・`)
23:36:03: -------------------------------
23:36:03: CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
23:36:03: CPU Speed: 3503MHz
23:36:03: Physical Memory:  4095MB Total, 4095MB Free
23:36:03: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
23:36:03: monitor 1: pos={0, 0}, size={1920, 1080}
23:36:03: monitor 2: pos={1920, 0}, size={2560, 1440}
23:36:03: Windows Version: 6.2 Build 9200
23:36:03: Aero is Enabled
23:36:03: OBS Modules:
23:36:03: Base Address     Module
23:36:03: 00BB0000         OBS.exe
23:36:03: 65910000         OBSApi.dll
23:36:03: 656D0000         DShowPlugin.dll
23:36:03: 65D00000         GraphicsCapture.dll
23:36:03: 656B0000         NoiseGate.dll
23:36:03: 65690000         PSVPlugin.dll
23:36:03: ------------------------------------------
23:36:03: Adapter 1
23:36:03:   Video Adapter: NVIDIA GeForce GTX 690
23:36:03:   Video Adapter Dedicated Video Memory: 2046488576
23:36:03:   Video Adapter Shared System Memory: 2147807232
23:36:03:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
23:36:03:   Video Adapter Output 2: pos={1920, 0}, size={2560, 1440}, attached=true
23:36:03: =====Stream Start: 2013-11-26, 23:36:03===============================================
23:36:03:   Multithreaded optimizations: On
23:36:03:   Base resolution: 1920x1080
23:36:03:   Output resolution: 1280x720
23:36:03: Loading up D3D10 on NVIDIA GeForce GTX 690...
23:36:03: Audio Format: 48000hz
23:36:03: Playback device Default
23:36:03: Using desktop audio input: SPDIF Interface (Burson Audio USB DAC )
23:36:03: Using auxilary audio input: Microphone (HTO STRIKER 7.1)
23:36:03: Audio Encoding: AAC
23:36:03:     bitrate: 160
23:36:03: Using Window Capture
23:36:03:     device: Logitech HD Webcam C525,
23:36:03:     device id \\?\usb#vid_046d&pid_0826&mi_02#7&14a4f5a9&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
23:36:03:     chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
23:36:03:     use buffering: false - 0, fourCC: 'I420'
23:36:03:     audio device: Disable,
23:36:03:     audio device id Disabled,
23:36:03:
23:36:03: Using directshow input
23:36:03: Using text output
23:36:03: Using graphics capture
23:36:03: Scene buffering time set to 700
23:36:03: Video Encoding: x264
23:36:03:     fps: 60
23:36:03:     width: 1280, height: 720
23:36:03:     preset: veryfast
23:36:03:     profile: high
23:36:03:     keyint: 120
23:36:03:     CBR: yes
23:36:03:     CFR: yes
23:36:03:     max bitrate: 3000
23:36:03:     buffer size: 3000
23:36:03: MMDeviceAudioSource: Frequency for device 'SPDIF Interface (Burson Audio USB DAC )' is 352800, samples per sec is 44100
23:36:03: MMDeviceAudioSource: Frequency for device 'Microphone (HTO STRIKER 7.1)' is 352800, samples per sec is 44100
23:36:04: Total frames encoded: 15, total frames duplicated: 0 (0.00%)
23:36:04: Total frames rendered: 64, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
23:36:05:
23:36:05: Profiler time results:
23:36:05:
23:36:05: ==============================================================
23:36:05: video thread frame - [100%] [avg time: 2.354 ms] [children: 28.9%] [unaccounted: 71.1%]
23:36:05: | scene->Preprocess - [22.6%] [avg time: 0.533 ms]
23:36:05: | GPU download and conversion - [6.29%] [avg time: 0.148 ms] [children: 6.58%] [unaccounted: -0.297%]
23:36:05: | | flush - [5.31%] [avg time: 0.125 ms]
23:36:05: | | CopyResource - [0.935%] [avg time: 0.022 ms]
23:36:05: | | conversion to 4:2:0 - [0.34%] [avg time: 0.008 ms]
23:36:05: Convert444Threads - [100%] [avg time: 0.824 ms] [children: 98.9%] [unaccounted: 1.09%]
23:36:05: | Convert444toNV12 - [98.9%] [avg time: 0.815 ms]
23:36:05: encoder thread frame - [100%] [avg time: 2.19 ms]
23:36:05:
23:36:05:
23:36:05: Profiler CPU results:
23:36:05:
23:36:05: video thread frame - [cpu time: avg 1.708 ms, total 109.375 ms] [avg calls per frame: 1]
23:36:05: | scene->Preprocess - [cpu time: avg 0.244 ms, total 15.625 ms] [avg calls per frame: 1]
23:36:05: | GPU download and conversion - [cpu time: avg 0.488 ms, total 31.25 ms] [avg calls per frame: 1]
23:36:05: | | flush - [cpu time: avg 0.244 ms, total 15.625 ms] [avg calls per frame: 1]
23:36:05: | | CopyResource - [cpu time: avg 0.919 ms, total 15.625 ms] [avg calls per frame: 0]
23:36:05: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
23:36:05: Convert444Threads - [cpu time: avg 0.976 ms, total 31.25 ms] [avg calls per frame: 2]
23:36:05: | Convert444toNV12 - [cpu time: avg 0.976 ms, total 31.25 ms] [avg calls per frame: 2]
23:36:05: encoder thread frame - [cpu time: avg 2.083 ms, total 31.25 ms] [avg calls per frame: 1]
23:36:05:
23:36:05: =====Stream End: 2013-11-26, 23:36:05=================================================
23:36:29: =====Stream Start: 2013-11-26, 23:36:29===============================================
23:36:29:   Multithreaded optimizations: On
23:36:29:   Base resolution: 1920x1080
23:36:29:   Output resolution: 1280x720
23:36:29: ------------------------------------------
23:36:29: Loading up D3D10 on NVIDIA GeForce GTX 690...
23:36:29: Audio Format: 48000hz
23:36:29: Playback device Default
23:36:29: Using desktop audio input: SPDIF Interface (Burson Audio USB DAC )
23:36:29: Using auxilary audio input: Microphone (HTO STRIKER 7.1)
23:36:29: Audio Encoding: AAC
23:36:29:     bitrate: 160
23:36:29: Using Window Capture
23:36:29:     device: Logitech HD Webcam C525,
23:36:29:     device id \\?\usb#vid_046d&pid_0826&mi_02#7&14a4f5a9&0&0002#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
23:36:29:     chosen type: I420, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-2000000
23:36:29:     use buffering: false - 0, fourCC: 'I420'
23:36:29:     audio device: Disable,
23:36:29:     audio device id Disabled,
23:36:29:
23:36:29: Using directshow input
23:36:30: Using text output
23:36:30: Using graphics capture
23:36:30: Scene buffering time set to 700
23:36:30: ------------------------------------------
23:36:30: Video Encoding: x264
23:36:30:     fps: 60
23:36:30:     width: 1280, height: 720
23:36:30:     preset: veryfast
23:36:30:     profile: high
23:36:30:     keyint: 120
23:36:30:     CBR: yes
23:36:30:     CFR: yes
23:36:30:     max bitrate: 3000
23:36:30:     buffer size: 3000
23:36:30: MMDeviceAudioSource: Frequency for device 'SPDIF Interface (Burson Audio USB DAC )' is 352800, samples per sec is 44100
23:36:30: MMDeviceAudioSource: Frequency for device 'Microphone (HTO STRIKER 7.1)' is 352800, samples per sec is 44100
23:36:32: Using RTMP service: Twitch / Justin.tv
23:36:32:   Server selection: rtmp://live-lax.justin.tv/app
23:36:32:   Interface: Intel(R) 82579V Gigabit Network Connection (ethernet, 1000 mbps)
23:36:32: Completed handshake with rtmp://live-lax.justin.tv/app in 47 ms.
23:36:32: SO_SNDBUF was at 65536
23:36:32: SO_SNDBUF is now 65536
23:36:33: SharedTexCapture hooked
23:36:35: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 131072 (buffer: 0 / 404480)
23:36:43: GraphicsCaptureSource::NewCapture:  eliminating old capture
23:36:43: SharedTexCapture hooked
23:36:45: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 262144 (buffer: 0 / 404480)
23:36:49: RTMPPublisher::SocketLoop: Increasing send buffer to ISB 524288 (buffer: 0 / 404480)
23:43:57: GraphicsCaptureSource::NewCapture:  eliminating old capture
23:43:57: SharedTexCapture hooked
23:44:03: GraphicsCaptureSource::NewCapture:  eliminating old capture
23:44:03: SharedTexCapture hooked
23:47:15: GraphicsCaptureSource::NewCapture:  eliminating old capture
23:47:15: SharedTexCapture hooked
23:47:53: GraphicsCaptureSource::NewCapture:  eliminating old capture
23:47:53: SharedTexCapture hooked
23:48:45: Capture window 0x001B0F3C invalid or changing, terminating capture
23:49:56: SharedTexCapture hooked
23:49:59: GraphicsCaptureSource::NewCapture:  eliminating old capture
23:49:59: SharedTexCapture hooked
00:00:42: Exit signal received, terminating capture
00:01:29: SharedTexCapture hooked
00:01:33: GraphicsCaptureSource::NewCapture:  eliminating old capture
00:01:33: SharedTexCapture hooked
00:02:15: Exit signal received, terminating capture
00:02:59: SharedTexCapture hooked
00:03:24: GraphicsCaptureSource::NewCapture:  eliminating old capture
00:03:24: SharedTexCapture hooked
00:03:38: GraphicsCaptureSource::NewCapture:  eliminating old capture
00:03:38: SharedTexCapture hooked
00:04:13: GraphicsCaptureSource::NewCapture:  eliminating old capture
00:04:13: SharedTexCapture hooked
00:04:14: GraphicsCaptureSource::NewCapture:  eliminating old capture
00:04:14: SharedTexCapture hooked
00:18:28: RTMPPublisher::SocketLoop: Received FD_CLOSE, 5013 ms since last send (buffer: 0 / 404480)
00:18:28: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
Things I have tried to resolve the issue:
1). Used LinX to test for stability issues with CPU/RAM (No errors found)
2). Reinstalled OBS
3). Updated video card drivers
This is my first time having stability issues with OBS and I am out of ideas.
Thanks for the help!
  • OBSCrashDump2013-11-27_5.zip
Lain
Lain
If it crashes in x264, then that usually is more indicative of hardware issues than software issues, more often than not. x264 is a library that OBS depends upon so it's not technically OBS' code. I'll check the crash data though.
BossBrew
Thanks for the quick reply about this issue! I used the search function before making this post and decided to try removing my CPU overclock to see if that was the issue. After returning to stock clock/voltages, the problem still persisted. I have been using OBS since the beginning of this year with and without overclock in place without issue until recently. RAM is also set to default values, no overclocking there either.
Besides a new mouse last week, there have been no other hardware changes which is strange considering the issue started a few days ago. I will be running more stability tests to see if I can isolate what hardware might be failing on me.
Thanks for the help and guiding me in the right direction for a solution to this.
