Bug Report Obs Crash when preview
djjonyo
I keep getting this every time i try to preview stream or start streaming
  • OBSCrashLog2013-06-20_5.txt
Lain
Lain
Could you zip and upload C:\Users\Jon\AppData\Roaming\OBS\crashDumps\OBSCrashDump2013-06-20_5.dmp here to the forums?
djjonyo
Sorry i didn't know i had to zip it for the .dmp
  • OBSCrashDump2013-06-20_5.zip
Lain
Lain
I'm not entirely sure yet but this -could- be driver related; could you see if updating your video card drivers changes anything at all?
R1CH
atkdx11disp.dll is still loaded, it doesn't look like it was disabled properly. You could try uninstalling it to be sure.
On an unrelated note, your crash dump also seems to show you have the BrowserProtect malware installed, you may wish to run a scan.
djjonyo
thanks for pointing out BrowserProtect i ran a scan and removed. I looked up atkdx11disp.dll, and it happens to be Gamer OSD also from Asus, i didnt have it running but apparently having on the drive is enough. Im uninstalling it and hopefully this works
