Bug Report OBS Crash when switching scenes
misterslin
Below is the minidump file that I get when swapping scenes. I get this error very regularly, and it's become a major issue for me. I noticed that even after OBS crashes, the stream continues running just fine until I say "no" to the popup that appears. I also have found that adding all of my scenes to global scenes helps reduce crashing, but it will still happen from time to time.
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: e0434352
Fault address: 000007FEFD53940D (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.624b
Windows version: 6.1 (Build 7601) Service Pack 1
CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Crashing thread stack trace:
Stack            EIP              Arg0             Arg1             Arg2             Arg3             Address
000000001D7DE610 000007FEFD53940D 000000001D7DE768 000000001D7DE6A8 0000000004F534C0 0000000046363950 kernelbase.dll!0x7fefd53940d
000000001D7DE6E0 000007FEF357630F 0000000000000000 0000000046363950 0000000046363950 0000000000000000 clr.dll!0x7fef357630f
000000001D7DE7D0 000007FEF375AEA2 0000000004BE7180 000000001D7DE9E0 0000000000000000 0000000004BE7060 clr.dll!0x7fef375aea2
000000001D7DE820 000007FEF348202A 000000001D9F9420 000000001D7DEA28 000007FEE3254F48 000000001D7DEC10 clr.dll!0x7fef348202a
000000001D7DE9C0 000007FEE36EA3EE 0000000004BE7180 000000001D7DEB70 000000001D7DEB80 000000000000006D mscorlib.ni.dll!0x7fee36ea3ee
000000001D7DEAA0 000007FEE361F77E 0000000000000030 00000000002B0000 0000000000000000 0000000000000028 mscorlib.ni.dll!0x7fee361f77e
000000001D7DEAD0 000007FEDCB14B90 000000001D7DEC10 00000000002D70C0 0000000000000000 0000000004BE0002 system.core.ni.dll!0x7fedcb14b90
000000001D7DEB10 000007FEE362CC46 000000000000006D 0000000000000000 0000000004A69BC0 00000000221EF5B0 mscorlib.ni.dll!0x7fee362cc46
000000001D7DEB70 000007FEF3419E03 0000000000000000 0000000000000000 0000000000000000 0000000000000000 clr.dll!0x7fef3419e03
000000001D7DEBB0 000007FEF3419E7E 0000000000000000 000000001D7DECA0 000000001D7DECC8 000007FEE35B73B0 clr.dll!0x7fef3419e7e
000000001D7DEBF0 000007FEF341C860 000000001D7DF360 0000000004A69BC0 0000000000000000 000000000000006D clr.dll!0x7fef341c860
000000001D7DEC80 000007FEF385D358 0000000004A69B78 000000001D7DF2D0 000000001D7DF380 000000001D7DF2D0 clr.dll!0x7fef385d358
000000001D7DED10 000007FEF342458C 000000001D7DF2D0 0000000000010004 0000000000000008 000000001D7DECD0 clr.dll!0x7fef342458c
000000001D7DED50 000007FEF342451A 0000000000000000 0000000000040000 000000001D9F9420 000007FEF33B31EC clr.dll!0x7fef342451a
000000001D7DEE50 000007FEF3424491 000000001D7DF078 000000001D9F9420 000000001D7DF2D0 000000001D9F9420 clr.dll!0x7fef3424491
000000001D7DEEE0 000007FEF359AD7C 0000000000000000 0000000003B2E850 000000001D7DF380 00000000002B8BE0 clr.dll!0x7fef359ad7c
000000001D7DEF10 000007FEF359AE2D 0000000000000002 0000000000000002 000000001D7DF2D0 000000001D7DF2D0 clr.dll!0x7fef359ae2d
000000001D7DF0E0 000007FEF359AD63 000000001D7DF2D0 0000000000000004 FFFFFFFFFFFFFFFE 000000001D7DF180 clr.dll!0x7fef359ad63
000000001D7DF120 000007FEF342451A 000000001D7DF3B0 000007FEF35701A9 0000000000000000 000000001D7DF398 clr.dll!0x7fef342451a
000000001D7DF220 000007FEF3424491 FFFFFFFFFFFFFFFF 000000001D9F9420 000000001D9F9420 0000000000000000 clr.dll!0x7fef3424491
000000001D7DF2B0 000007FEF34245EF 0000000000000002 FFFFFFFFFFFFFFFE FFFFFFFFFFFFFFFE 0000000000000000 clr.dll!0x7fef34245ef
000000001D7DF310 000007FEF385D4C5 000000000001000C 0000000000000001 000000001D9F9420 0000000000000001 clr.dll!0x7fef385d4c5
000000001D7DF3A0 000007FEF385D3C9 000000020002000C 000000010001000C 000000010001000C 0000000000000000 clr.dll!0x7fef385d3c9
000000001D7DF3D0 000007FEF35831B8 0000000000000000 00000000002B0000 0000000000000001 0000000000000000 clr.dll!0x7fef35831b8
000000001D7DF4C0 000007FEF34833DE 0000000000000000 0000000000000000 0000000000000000 0000000000000000 clr.dll!0x7fef34833de
000000001D7DFE00 00000000773059ED 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x773059ed
000000001D7DFE30 000000007743C541 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7743c541
A minidump was saved to C:\Users\Steve\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-06-15_2.dmp.
List of loaded modules:
Base Address                      Module
  • OBSCrashLog2014-06-15_2.txt
R1CH
Your CLR plugin is crashing, try removing it. It's recommended to use the 32 bit version also.
