OBS crash
TheBarracudaxX
After the update it just stopped working and i already updated all the drivers on my PC and still doesn´t work :(
  • Crash 2025-01-24 17-26-28.txt
HaaDiiDaa
Can confirm, after uninstalling the Nvidia Audio Enhancements SDK, OBS started up and works as expected.
JRHorse
For what it’s worth, I recently had an issue where running OBS was disconnecting my internet. I traced the problem to the NVIDIA background removal plugin that was running with my web camera. Removing that plugin solved my problem.
Think that plugin comes from the same website as the audio plugin mentioned here. They are all marked as beta.
