OBS crashes on startup
coreXtream
Hey,
it happens from here to then that obs takes long and crashes, but after a 2nd or 3rd try it does eventually open then.
Now I am trying to open it for around 20min and nothing helps it just starts, no response and closes itself.
I attached the current log file to this thread, hope I can find some help. I do use SE.Live and also reinstalled it. Nothing changed.
if you need any other logs or information just let me know
  • 2022-08-31 17-17-56.txt
You're using SE.live. Please contact them for support.
Alternatively, uninstall it. Then uninstall and reinstall OBS in order to fix the changes made by SE.live. Now please do a test stream/recording of more than 30 seconds and post the log file here.
coreXtream
I removed SE.live and reinstalled OBS Studio without any changes. I did notice that obs spiked the CPU usage to 100% and shortly after closed itself.
not sure if I can do anything about that or if that's simply my PC not getting it done.
i5 -7600k it got some years behind
