OBS crashes then crashes my pc along with it
forestdotblend
I can't remember well what i did to cause this, it may be something gpu related but i really can't tell.
As soon as i open the exe my computer goes into a black screen and restarts, please help me.
(File attached is the most recent, when it crashes it doesn't write a log so i don't know if this file will help.)
  • Crash 2025-06-19 12-52-04.txt
forestdotblend
Alright so, a user on discord helped me fix it and apparently it was due to capture method being set to something other than windows 10, it's weird because i wasn't using window capture, i was using game capture but its fixed now.
If anyone else has this problem, run OBS without the program being open and remove whatever capture method you're using.
