Bug Report OBS Crashes when stream is stopped & OBS wont stream
Lewis Hodgeon
I am on windows 8.1 and every time I click stop streaming OBS crashes & not to mention but the program will not stream period
This crash appears to have occured in the 'c:\windows\system32\kernelbase.dll' module.
**** UNHANDLED EXCEPTION: 80000003
Fault address: 00007FFADAD09376 (c:\windows\system32\kernelbase.dll)
OBS version: Open Broadcaster Software v0.613b
Windows version: 6.2 (Build 9200)
CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Crashing thread stack trace:
000000000068EE38 00007FFADAD09376 00007FFAAFFA7910 0000000000007530 000000000068ED98 0000000000000000 kernelbase.dll!0x7ffadad09376
000000000068EE40 00007FFAAFE1EBB3 0000000000000001 000000000068F010 0000000002650800 0000000000000002 obsapi.dll!OSTerminateThread+0x33
000000000068EE70 00007FF6A3D56368 000000000068F010 0000000002650800 0000000000000000 00007FFADD7D838F obs.exe!OBS::Stop+0x178
000000000068EF10 00007FF6A3D500AE 00000000006F0B30 0000000000000001 0000000002661000 0000000002650800 obs.exe!OBS::~OBS+0x4e
000000000068F380 00007FF6A3D50034 0000000010F50649 000000000068F4B0 0000000002661000 0000000002661000 obs.exe!OBS::`vector deleting destructor'+0x14
000000000068F3B0 00007FF6A3D489BB 0000000000000000 0000000000000000 00007FF6A3D20000 0000000000000000 obs.exe!WinMain+0xa8b
000000000068F950 00007FF6A3DC5CF0 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!strstr+0x1ac
000000000068FA00 00007FFADBBD15DD 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ffadbbd15dd
000000000068FA30 00007FFADD7B43D1 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffadd7b43d1
Video thread stack trace:
00000000149BF2C8 00007FFADD7D65BA 0000000000000001 00007FFAAFE0C49A 0000000002682B78 0000000000000001 ntdll.dll!0x7ffadd7d65ba
00000000149BF2D0 00007FFADAC31148 0000000000000001 0000000000000001 0002CE2500000000 0000000000000200 kernelbase.dll!0x7ffadac31148
00000000149BF370 00007FF6A3D5C377 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureLoop+0x1e27
00000000149BF800 00007FF6A3D58E89 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::MainCaptureThread+0x9
00000000149BF830 00007FFADBBD15DD 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ffadbbd15dd
00000000149BF860 00007FFADD7B43D1 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffadd7b43d1
Encode thread stack trace:
00000000148BF838 00007FFADD7D68BA 00000000148BF8F8 00007FFAAFE0C49A 0000000000000000 0000000002650800 ntdll.dll!0x7ffadd7d68ba
00000000148BF840 00007FFADAC3124A 000000000000000F 0000000000000000 0000000000000000 0000000000000000 kernelbase.dll!0x7ffadac3124a
00000000148BF8E0 00007FF6A3D59C1D 0000000000000001 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::EncodeLoop+0x18d
00000000148BFA20 00007FF6A3D58E79 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!OBS::EncodeThread+0x9
00000000148BFA50 00007FFADBBD15DD 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x7ffadbbd15dd
00000000148BFA80 00007FFADD7B43D1 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffadd7b43d1
A minidump was saved to C:\Users\Lew\AppData\Roaming\OBS\crashDumps\OBSCrashDump2014-04-07_9.dmp.
List of loaded modules:
Base Address Module
  • OBSCrashDump2014-04-07_9.dmp
R1CH
Are you using the latest version of VAC? Old or pirated versions don't work well with OBS due to timestamp issues. You may want to set VAC to your secondary input and mix it with the audio repeater program instead of using VAC as your primary device.
