Obs crashing after a few seconds!!
BlueMart1n
Hello, in the past few weeks, OBS has been crashing randomly after a few seconds or minutes from opening it.
I think the problem is SE.Live (a plug-in made by StreamElements) because when I uninstalled it everything was warking just fine. My friends have no problem with the plug-in, so it's just on my PC.
Anyone knows how I could fix this problem?
Thanks!!
  • 2024-02-28 15-33-39.txt
Issues with SE plugin must be asked to them directly.
The best solution is to fully remove the plugin using the uninstaller they provide, then go to %appdata%\obs-studio\ and manually delete the leftover files from this plugin. Now you need to uninstall and reinstall OBS in order to fix any other changes this plugin may have done.
