Bug Report OBS Crashing asap I hit preview stream or Start stream
aGOneStep
I press Preview Stream and it crashed.
I tryed Start Stream and it crashed.
From preview stream crash:
Fault address: 0051A674 (<unknown>)
OBS version: Open Broadcaster Software v0.472b
Windows version: 6.1 (Build 7601) Service Pack 1
Crashing thread stack trace:
1628F92C 0051A674 0052101C 00000001 1628F9B0 00000000 <unknown>!0x51a674
1628F988 670F1D0C 0051A674 00000001 1628F9F8 00000000 d3d11.dll!0x670f1d0c
1628F9DC 00C3B858 005437A4 B7B9A279 00000000 00000000 obs.exe!D3D10System::SetRenderTarget+0x48
1628F9F8 00C56ADE 0000000C 00000000 00000000 00000000 obs.exe!OBS::MainCaptureLoop+0xa4e
1628FAA4 6F62335D 6EE30000 00000002 00000000 2841BBB4 nvd3dum.dll!0x6f62335d
1628FB2C 77619950 7761A0EA 00000000 00000000 00553FA8 ntdll.dll!0x77619950
1628FBB0 7761A13C 00000000 00000000 00553FA8 00CE2A80 ntdll.dll!0x7761a13c
1628FBB4 7761A0EA 77601DB5 77619E61 6178CFAC 00000000 ntdll.dll!0x7761a0ea
1628FBE8 7761A0DA 6178CFAC 00000000 00000000 00000000 ntdll.dll!0x7761a0da
1628FBF0 77619E61 00000000 00000000 00000000 00000000 ntdll.dll!0x77619e61
1628FBF4 6178CFAC 00000000 00000000 00000000 00000000 <unknown>!0x6178cfac
From Start Stream Crash:
Fault address: 004B9C94 (<unknown>)
1D90F4EC 004B9C94 004BF034 00000001 1D90F570 00000000 <unknown>!0x4b9c94
1D90F548 670F1D0C 004B9C94 00000001 1D90F5B8 00000000 d3d11.dll!0x670f1d0c
1D90F59C 0031B858 004E26E4 B94E85B4 00000000 00000000 obs.exe!D3D10System::SetRenderTarget+0x48
1D90F5B8 00336ADE BDF817C2 00000000 00000000 00000000 obs.exe!OBS::MainCaptureLoop+0xa4e
1D90F664 6F623346 00000000 004082AA 00000000 00000000 nvd3dum.dll!0x6f623346
1D90F694 6F61E935 00000000 00000000 00000000 00000000 nvd3dum.dll!0x6f61e935
I couldn't upload the .dmp files, it was not allowed to added the extended things in here.
  • OBSCrashLog2013-03-31_2.txt
  • OBSCrashLog2013-03-31_3.txt
aGOneStep
I added some logfiles to the crash aswell
  • 2013-03-31-1034-16.log
  • 2013-03-31-1036-50.log
aGOneStep
I cant do that :( I went into the IRC channel, and they asked me to remove everything in \appdata\ maps so all is gone. But I have a new problem now. That I have no clue why is happening. I can describe that and maybe you KNOW what to do..
So, after this post. I downloaded the testbuild. Then I could Preview stream and Start Stream. But then I switched scenes in OBS. and Sc2 crashed.
After that happend I "reinstalled" the stable build. And then the same problem have "moved over" to the stable build. I could preview and start streaming. But if I switched scene sc2 crashed.
Furious as I was I removed everyhing again from \appdata\ and all that jazz. Reinstalled SC2 and tryed again, now with the testbuild. Same problem.. Sc2 Crash if I switched scenes.
To add to this, I use Game Capture. And after all this. I added everything as a global source. And added it to the scenes that way, then the "problem was solved" kinda. I could switch scenes. But If i hit "Stop preview or Stop Streaming".. Guess what, sc2 crashes!
Cause this issue seemes to be sc2 related I dont get a file from OBS to report. I also tryed Game Capture with other games, no problems at all. I could switch scenes and hit the buttons start / stop without any crashes.
Im all out of hope atm. I have no clue what to do. I have no clue why things are messed up! Please R1CH I know you are awesome, please help <3
R1CH
Game capture definitely shouldn't be crashing SC2. If possible, please post the SC2 crash log text here. Based on your OBS crash, I feel like you have some app or hook program that is interfering with proper DirectX operation.
aGOneStep
So, where can I get that crashlog? Cause the only thing I get from the sc2 crash is a box where it says :
"An Unexpected fatal error occurred.
To help us identify the problem. Please describe what you were doing when the error occurred
<big emtpy box for me to put text in>
Please use the Report ID below when communicating with Blizzard about this issue
540C419B-F6C3-4761-B6DC-CBCCDEDA558E
<box with a text send to blizz checked> <button Reopen> <button close>"
aGOneStep
I must say, that I have solved the problem.
Someone it was the graphic drivers that cause all this problems. Now, I have reversed them and its works perfectly again!
Lain
Lain
what he probably means is he downgraded his drivers. the question is which version he downgraded to. there are some newer nvidia drivers that are having some issues apparently
