OBS Crashing excessive
I have been using OBS for years and usually able to troubleshoot any issues. This one has me truly stumped. I have not changed any settings and have been using the same plugins for months. I usually record my gaming content and now OBS is literally crashing every 20 seconds when I hit record. It is up to date and the main plug in I use (source record) is also up to date. I have uninstalled and reinstalled both OBS and the plugin. Attached are the most recent logs and below is the log link. Any help is appreciated so that I can get back to work! Thank you.
  • 2025-04-13 12-21-36.txt
  • 2025-04-13 12-24-39.txt
  • 2025-04-13 12-25-03.txt
prgmitchell
Hello, I mistyped. The three most recent crash logs are attached.
These are not crash reports
If you do not mean that OBS is actually crashing then I'd recommend testing in safe mode, it would probably be a plugin that is causing issues and not OBS itself.
OBS could not have been in safe mode when this crash occurred, it is with your source record plugin.
Do I have to remove the plug-in completely and not use it? Prior to today I've had zero problems with the plug in. I understand that this plug in is the problem now, but wh is a problem I guess my follow up question is.
Thank you again for your help!
prgmitchell
I'd make sure it is up to date and if not, reach out to the plugin developer for support.
