OBS Crashing randomly every 10-30 minutes
Crinlorite
Good afternoon,
I've been trying to solve this using less browser sources, less quality, less framerate, and I don't find a solution, the program doesn't completely crashes, it just goes stuck on preview screen and it stops sending audio and video to the stream on Twitch or any other places I stream to, so I don't have a crash log, I'll upload a log that I've checked and says several errors, but I don't know how to solve them.
If anyone knows how to prevent the crashes, I'd be very happy, since I haven't been able to stream for the last week.
Please help me, thanks,
Crinlorite.
  • 2023-02-09 23-41-54.txt
sandrix
Disable HAGS
23:41:54.781: Hardware GPU Scheduler: On
Of the huge number of lines in your report, most of the errors are related to Virtual Audio Cable.
00:00:27.995: Device '[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]' invalidated. Retrying (source: Spotify)
Try delete it if the first step didn't work.
sandrix
I am in the same boat... hopefully someone knows the answer
Use the analyzer, it will indicate the potential causes of the problem.
