OBS crashing weirdly
JACOBcze
Hello, I upgraded my PC from DDR4 to DDR5 (motherboard, CPU, RAM) and Win10 to Win11.
After that my OBS started mysteriously crashing. What happens is that the bitrate drops to 0 (still shows green and doesnt disconnect) and the whole app freezes. There is no notification, only after I take any action in OBS myself it states the app Unresponsive.
It's insanely annoying and no idea why this happens, I send one of my regular logs in case you guys can figure something out (crash logs dont work for it).
I tried complete reinstall, delete all plugins and using an older version of OBS, nothing helped.
  • 2024-01-29 15-02-17.txt
You have intalled streamelements plugins. Any issue with it must be ask to them.
JACOBcze
Already wrote I deleted all plugins, didn't fix the issue.
It's there:
15:02:22.948: obs-streamelements-bootstrap: initialized: C:\Program Files\obs-studio\obs-plugins\64bit\obs-streamelements-core
15:02:22.949: obs-streamelements-bootstrap: skipping trying to load Qt5 flavor of a plugin for OBS version 30.0.0
15:02:22.949: obs-streamelements-bootstrap: loaded module: C:\Program Files\obs-studio\obs-plugins\64bit\obs-streamelements
15:02:22.949: obs-streamelements: initializing
15:02:22.951: obs-streamelements: checking for updates
15:02:22.951: obs-streamelements: ShowStatusBarMessage: Checking for updates...
15:02:22.951: obs-streamelements: context->manifestFilePath: C:\Users\Jacob\AppData\Roaming\obs-studio/plugin_config/obs-streamelements/obs-streamelements.manifest
15:02:22.951: obs-streamelements: config_folder_path: C:\Users\Jacob\AppData\Roaming\obs-studio/plugin_config/obs-streamelements/
15:02:22.952: obs-streamelements: creating signal handlers
15:02:22.952: obs-streamelements: connecting signal handlers
15:02:22.952: obs-streamelements: initialized
15:02:22.952: obs-streamelements-bootstrap: initialized: C:\Program Files\obs-studio\obs-plugins\64bit\obs-streamelements
JACOBcze
Update: I did the recommendation from analyzer thanks to @PaiSand and turned off Hardware-accelerated GPU Scheduler. As I said the crash happens sporadically, but after turning it off, it didnt crash for 3 streams straight.
It would also make sense that I might had it turned off on my win10 and it auto turned on on win11 when I changed my PC.
If I no longer respond to this thread this was the solution.
