OBS crashing when closing ( old plugin maybe ?)
Sawan
Yeah so I have this problem for a while now, OBS is working fine but when I close it, it will instead crash and give me a crash report. Then next time I launch it, it ask me if I want to launch it in safe mode ( which I don't since otherwise it works fine). I suspect maybe and old plugin but I was unable to identify which one if that is the case.
Here is my latest crash report and log file. Let me know if you need more information. Thanks
  • Crash 2025-08-17 22-05-16.txt
  • 2025-08-18 13-56-55.txt
Crashes on exit are typically due to third party plugins. In your case is move transition.
Please verify it's updated and compatible with the OBS version you're using. Use the discussion section on this particular plugin page to ask for support on it.
All the above mentioned also apply to the other plugins you have installed.
