OBS disconnects often
Hunnerman
I'm fairly new to OBS and I would say I'm an average PC user. OBS disconnects almost every time I use it and from what I can tell It's due to my internet. I have attached the log file and I'm hoping someone can shed some light on the issue for me?
Thanks in advance!
Cheers,
Hunter L.
  • 2021-12-27 20-00-09.txt
FerretBomb
Your provided log shows two sessions, both manually stopped, with one instance of your connection dropping out.
21:37:31.815: WriteN, RTMP send error 10054 (4097 bytes)
21:37:31.816: WriteN, RTMP send error 10054 (80 bytes)
21:37:31.816: WriteN, RTMP send error 10038 (42 bytes)
21:37:31.816: [rtmp stream: 'simple_stream'] Disconnected from rtmp://yto.contribute.live-video.net/app
21:37:31.816: Output 'simple_stream': Reconnecting in 10 seconds..
Yes, your network connection dropping out is causing the issue.
Troubleshooting network issues goes beyond the scope of the OBS support forums though. Most likely you'll need to contact your ISP to get the issue resolved.
