obs.dll crashing on 27 release candidate
nelsonsauvin
I realize I'm running a release candidate but figured I'd post these logs in case y'all find it helpful. Also any troubleshooting tips would be very welcome. I'm about to just do a clean install.
short version:
Unhandled exception: c0000005
Date/Time: 2021-04-19, 21:21:27
Fault address: 7FFB05429573 (c:\program files\obs-studio\bin\64bit\obs.dll)
libobs version: 27.0.0-rc2 (64-bit)
Windows version: 10.0 build 19042 (release: 2009; revision: 928; 64-bit)
CPU: AMD Ryzen 7 2700X Eight-Core Processor
  • Crash 2021-04-19 21-21-28.txt
WizardCM
Community Helper
If you load 26.1.2 and then 27rc2, the crash should go away. Otherwise, you can wait for rc3 which will have a full fix for this issue.
In future, please report crashes in the Release Candidate forum thread, so that all reports are in one place.
