KirbysPlanet
hey guys I used to run obs at 30FPS but that would make some games like GYLT to stutter on Stream while the game itself runs smooth on pc as OBS drops frames from 30FPS to 24FPS
Yesterday I tried running obs at 60FPS now it runs stream good and even if it drops fps it drops to 48FPS and comes back to 52FPS which is smooth for stream, but now with 60FPS it gives me ENCODER OVERLOADING ERROR ( i wonder if i keep using that it will harm my pc in anyway )
m using software encoding and not using NVENC from NVIDIA GT730 2GB DDR5 as using NVENC would give me the same result
I thought my Current scene had alot of items so i created a seperate scene to test it out and when using DISPLAY CAPTURE it stays stable, but when using WINDOW Capture it fluctuates sometimes as mentioned above from 60FPS to 48-52FPS
below is log taken yesterday after trying above mentioned things.
if anyone can help would appreciate
also do notify if keeping ENCODER OVERLOADING would harm my pc in anyway?
below is complete log:
  • 2024-06-08 16-06-38.txt
