Obs Failed to connect (but stream still alive)
eaeniko
So.. Im testing the new aitum plugin for multistreaming, but after trying to use the AVI option, I cant stream anymore, it shows this error when I start a stream (main output on twitch) but the broadcast still alive, but if I start another stream with any multistream plugin the obs crash.
Any ideia what happen and how to fix? I stream since 2016 and this is the first time I had such problem.
Heres the log file too:
  • 2024-08-09 10-53-51.txt
You should contact directly the dev of the plugin. And remove it so you can still use OBS.
