OBS Failing to stop recording
overchargedegg
I have recently had an issue where OBS is failing stop recording. I have moved to Windows 11 which seemed to be the start of my issue. I have performed clean installs of OBS and set up fresh profiles a number of times. I have attached the logs, please let me know if you need anything further.
The issue is not consistent. Sometimes it stops fine, others it doesn't and the only way to get it to stop is task manager OBS to terminate. I am also running OBS as administrator. I have a fairly high end PC and have had no trouble with this in the 7 years I've used OBS. Any advice, greatly appreciated!
  • 2025-07-31 13-48-26.txt
  • 2025-07-31 12-52-20.txt
  • 2025-07-31 12-43-23.txt
