Question / Help OBS font size so small
Treytrey134
the bottom menu for the program is tiny af. i know it has a problem with the fact that my monitor is 4k.
  • Profile_ Untitled - Scenes_ scenes - Open Broadcaster Software v0.657b 6_23_2016 11_52_37 PM.png
FerretBomb
You need to disable DPI scaling at the OS level. OBS is not compatible with it, and it cannot be disabled only for OBS. It has to be system-wide fully disabled.
