OBS keeps crashing/freezing!
TheLonleyOlive
Hello there,
My OBS keeps crashing/freezing! Its been happening for a while and I dont really know why its doing it. Loved if someone helped me with this. The only thing is that I cant get crash reports, Anyone know why?
Love if you helped!
I also have been having same issue. OBS crashes and freezes/ not responding. Doesn't matter if i am live streaming or not live. any help would be great. I have crash reports but they seem to have old dates on them. I am not sure where anything new is. I have new log files. see attachments. https://obsproject.com/logs/gPSUe9Ac54NcsE95
  • Crash 2023-07-10 15-46-32.txt
  • 2024-03-09 12-04-47.txt
TheLonleyOlive
That is literally the same! Same thing, got the same with the crash reports but thought they were old so wouldn't help LUL!
Glad someone also has the same issue!
Gloom_guy
I'm in the same situation, OBS can freeze the computer just by being open without stream, can't reset the GPU, music continue to play / sometimes not, a few hours ago after the crash I open obs then my apps, google steam and my game and in 10s freeze and it was over, I restart my computer and do the same again and freeze, sometimes I can stream and play 1h and I'll freeze, and right after I'll be able to stream and play 8h before freezing again. I've been able to get a crash file a few times, but it only froze the stream and not my pc. I've been struggling with this for a month now and I can't find any solution, I've tried everything, eventually I'll have to update my bios, which dates back to 2022.
I'll provide the few crash files that i got but i don't think they'll be tied to the problem
  • Crash_2024-01-18_16-25-58.txt
  • Crash_2024-01-18_16-48-14.txt
  • Crash_2024-02-11_22-12-04.txt
  • Crash_2024-02-12_11-56-48.txt
  • Crash_2024-03-08_03-06-23.txt
On your crash report:
Failed to recreate D3D11: Failed to create swap RTV (80070057)
16:54:02.305: Device Remove/Reset! Rebuilding all assets...
Unfortunately your GPU is crashing, you'll need to resolve that first (drivers, overclocking, poor PSU, failing GPU, etc).
