OBS keeps crashing - Fresh install on iMac newly upgraded to BigSur
JamaicanSounds
I've been having issues with OBS crashing on my Imac. I had been using the Apple Hardware Encoder in OBS for some time, but that caused some other issues that I was unaware of. After reading a number of articles, I switched to x264, but now OBS keeps crashing. The stream quality is far better than the Hardware Encoder, so trying to figure out the issue.
After the first few crashes, I finally took the step and upgraded my iMac to Big Sur hoping that might fix the issue. I then deleted OBS and the Application Support files in Library. Restarted everything, installed OBS fresh, got everything set up and it's still crashing. I have included the OBS Log from the latest crash as attached a txt of the Apple Crash Report (message was too long with the full thing. Thanks!)
Greatly appreciate anyone that can offer their input on what might be causing this and how to fix it.
Thanks!
OBS LOG FILE
04:15:45.925: CPU Name: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
04:15:45.926: CPU Speed: 3400MHz
04:15:45.926: Physical Cores: 4, Logical Cores: 4
04:15:45.926: Physical Memory: 65536MB Total
04:15:45.926: OS Name: Mac OS X
04:15:45.926: OS Version: Version 11.5.1 (Build 20G80)
04:15:45.926: Kernel Version: 20.6.0
04:15:45.936: hotkeys-cocoa: Using layout 'com.apple.keylayout.US'
04:15:45.937: Current Date/Time: 2021-08-07, 04:15:45
04:15:45.937: Browser Hardware Acceleration: true
04:15:45.937: Portable mode: false
04:15:46.044: OBS 27.0.1 (mac)
04:15:46.044: ---------------------------------
04:15:46.045: ---------------------------------
04:15:46.045: audio settings reset:
04:15:46.045: samples per sec: 48000
04:15:46.045: speakers: 2
04:15:46.046: ---------------------------------
04:15:46.046: Initializing OpenGL...
04:15:46.069: Loading up OpenGL on adapter ATI Technologies Inc. AMD Radeon Pro 560 OpenGL Engine
04:15:46.069: OpenGL loaded successfully, version 4.1 ATI-4.6.20, shading language 4.10
04:15:46.185: ---------------------------------
04:15:46.185: video settings reset:
04:15:46.185: base resolution: 1920x1080
04:15:46.185: output resolution: 1280x720
04:15:46.185: downscale filter: Bicubic
04:15:46.185: fps: 60/1
04:15:46.185: format: NV12
04:15:46.185: YUV mode: 709/Partial
04:15:46.185: NV12 texture support not available
04:15:46.185: Audio monitoring device:
04:15:46.185: name: Default
04:15:46.185: id: default
04:15:46.186: ---------------------------------
04:15:46.188: Failed to load 'en-US' text for module: 'decklink-captions.so'
04:15:46.190: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
04:15:46.198: os_dlopen(libpython3.9.dylib->libpython3.9.dylib): dlopen(libpython3.9.dylib, 257): image not found
04:15:46.198:
04:15:46.198: [Python] Could not load library: libpython3.9.dylib
04:15:46.372: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
04:15:46.372: No blackmagic support
04:15:46.374: [mac-virtualcam] version=1.3.0
04:15:46.451: obs_register_encoder: Encoder id 'com.apple.videotoolbox.videoencoder.h264.gva' already exists! Duplicate library?
04:15:46.451: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
04:15:46.455: [obs-browser]: Version 2.14.3
04:15:46.455: [obs-browser]: CEF Version 85.0.0-HEAD.2273+g93b66a0+chromium-85.0.4183.121
04:15:46.489: VLC found, VLC video source enabled
04:15:46.563: [obs-ndi] hello ! (version 4.9.0)
04:15:46.563: [obs-ndi] Trying ''
04:15:46.563: [obs-ndi] Trying '/usr/lib'
04:15:46.563: [obs-ndi] Trying '/usr/local/lib'
04:15:46.563: [obs-ndi] Found NDI library at '/usr/local/lib/libndi.4.dylib'
04:15:46.565: [obs-ndi] NDI runtime loaded successfully
04:15:46.565: [obs-ndi] NDI library initialized successfully (NDI SDK APPLE 11:50:41 Apr 1 2020 4.5.1)
04:15:46.567: ---------------------------------
04:15:46.567: Loaded Modules:
04:15:46.567: obs-ndi.so
04:15:46.567: media-controls.so
04:15:46.567: vlc-video.so
04:15:46.567: text-freetype2.so
04:15:46.567: rtmp-services.so
04:15:46.567: obs-x264.so
04:15:46.567: obs-vst.so
04:15:46.567: obs-transitions.so
04:15:46.567: obs-outputs.so
04:15:46.567: obs-filters.so
04:15:46.567: obs-ffmpeg.so
04:15:46.567: obs-browser.so
04:15:46.567: mac-vth264.so
04:15:46.567: mac-virtualcam.so
04:15:46.567: mac-syphon.so
04:15:46.567: mac-decklink.so
04:15:46.567: mac-capture.so
04:15:46.567: mac-avcapture.so
04:15:46.567: image-source.so
04:15:46.567: frontend-tools.so
04:15:46.567: decklink-ouput-ui.so
04:15:46.567: decklink-captions.so
04:15:46.567: coreaudio-encoder.so
04:15:46.567: ==== Startup complete ===============================================
04:15:46.600: Switched to Preview/Program mode
04:15:46.600: ------------------------------------------------
04:15:46.605: All scene data cleared
04:15:46.605: ------------------------------------------------
04:15:46.761: Switched to scene 'Video Shuffle'
04:15:46.763: ------------------------------------------------
04:15:46.763: Loaded scenes:
04:15:46.763: - scene 'Video Shuffle':
04:15:46.763: - source: 'JS Bottom' (image_source)
04:15:46.763: - source: 'Video List' (vlc_source)
04:15:51.511: Switched to scene 'Video Shuffle'
04:15:51.515: Switched to regular Preview mode
04:15:51.515: ------------------------------------------------
04:15:53.761: ---------------------------------
04:15:53.761: [x264 encoder: 'simple_h264_stream'] preset: veryfast
04:15:53.761: [x264 encoder: 'simple_h264_stream'] settings:
04:15:53.761: rate_control: CBR
04:15:53.761: bitrate: 3500
04:15:53.761: buffer size: 3500
04:15:53.761: crf: 23
04:15:53.761: fps_num: 60
04:15:53.761: fps_den: 1
04:15:53.761: width: 1280
04:15:53.761: height: 720
04:15:53.761: keyint: 120
04:15:53.761:
04:15:53.767: [CoreAudio AAC: 'simple_aac']: settings:
04:15:53.767: mode: AAC
04:15:53.767: bitrate: 160
04:15:53.767: sample rate: 48000
04:15:53.767: cbr: on
04:15:53.767: output buffer: 1536
04:15:53.767: [rtmp stream: 'simple_stream'] Connecting to RTMP URL rtmp://live.restream.io/live...
04:15:55.147: [rtmp stream: 'simple_stream'] Connection to rtmp://live.restream.io/live successful
04:15:55.150: ==== Streaming Start ===============================================
  • Apple Crash Report.txt
