Bug Report OBS Keeps turning my stream off randomly
Valliate
My OBS used to be fine about 2 weeks ago, and now it continues to turn my stream off randomly after 5 minutes of streaming. I get no error or crash report, my stream simply goes offline and I can not stream for over 5 minutes without the stream shutting down on me, I have tried downloading older versions of OBS thinking it might have been an update, but it continues to have this problem no matter what version I use. It is srsly frustrating, because it use to be perfectly fine when I streamed 2 weeks ago and all of a sudden this error completely prevents me from streaming fluently. Please Help!
Lain
Lain
Please post a log file, the instructions are at the top of the forum - Here's the thread on how to do so: viewtopic.php?f=6&t=97
For every effect there is a cause, so your computer/internet technically did not just randomly decide to start doing this, it happened due to a specific cause which has not yet been determined. Post that log and we can at least get some idea and try to help you determine that cause and/or a fix.
(And please don't kill me, but if this is a disconnection problem, then just for future reference this should be in the questions/help section, because that's something people commonly have issues with due to a variety of things unrelated to the application. If this is an actual crash that shuts down the app or freezes it, or definitely without a doubt doesn't work as intended, then it would belong here. I just sort of try to sort these things so I can more clearly see bugs/crashes over general common problems)
Valliate
I apologize if this is in the wrong section, I am just not exactly sure what the problem is.
  • 2013-08-18-0830-13.log
  • 2013-08-17-2343-44.log
  • 2013-08-16-2220-32.log
Lain
Lain
It would appear at first glance that you're just getting disconnected from the server due to large amounts of frame drops. You may either have to try a new server or lower your bitrate, apparently either your internet or the routing to the server can't seem to handle what you're throwing at it.
