OBS kept on disconnecting every 5 mins or so during my stream
tweedledumdee
Exactly what it says on the title. :( Just wanna have an idea what's causing it.
  • 2020-12-08 21-21-02.txt
Lawrence_SoCal
Could be LOTS of things, including those NOT captured in the log.
For example, are you monitoring ALL other devices using Internet bandwidth while you are streaming? are you monitoring your Internet connection throughput (separate from OBS stream)? Have you optimized your Windows setup to eliminate unnecessary background tasks and services which might interfere? Are you using Task Manager/Resource Monitor to oversee resource utilization on your system to make sure you aren't bottlenecking?
With that said, you have an older CPU and are re-scaling, aren't running Win10 v2004,
Others may mention running OBS Admin as admin (which is generally a bad idea, unless resource constrained, which you likely are..)
and you are running at 60 fps? try dropping to 30fps to get a stable stream, then see about increasing settings
and to minimize resource load on PC, have Base & Output Resolution be the same
This in the log indicates you have a network issue
21:36:15.728: Output 'simple_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 1119 (3.3%)
21:39:33.907: Output 'simple_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 1109 (9.9%)
Now, is your PC completely overloaded, and that why network issue, or is network its own issue? can't tell from this log
I'm not a gamer, but that is a quick observation. Some of your other settings may not be optimized for gaming on an older CPU. I don't following gaming recommendations, so can't comment. But if you search this forum, you'll see lots of comments about Aero Mode, Game mode, etc. And if you are using OBS to stream (and can record), why also using
21:21:02.678: Game DVR Background Recording: On
Michal-Jordan
Are you, for example, keeping track of all other devices that are utilising Internet bandwidth while you're streaming? Are you checking the throughput of your Internet connection (not the OBS stream)? Have you adjusted your Windows setup to remove any superfluous background processes or services that might cause problems? Are you utilising Task Manager/Resource Monitor to keep track on your system's resource use to ensure you're not bottlenecking?
With that stated, you're rescaling since you have an older CPU and aren't on Win10 v2004.
Others may suggest running OBS Admin as an administrator; see How To Solve antimalware. (which is generally a bad idea, unless resource constrained, which you likely are..)
and you're shooting at 60 frames per second? To achieve a consistent broadcast, consider lowering the frame rate to 30fps.
Michal-Jordan
Others may advise running OBS Admin as an administrator; see How To Solve Antimalware Problems for more information. (which is usually a horrible idea unless you're short on cash, which you most certainly are.)
Michal-Jordan
