OBS Log Help
MadRadIan
Hello and thank you for any help that you can offer in advance. I recently did a clean install of my computer and am now attempting to clean up my OBS. I've had a few problems lately, one of which was caused by a Logitech driver that installed itself due to my headset. However, I started this project due to the fact that OBS hangs when I close it-sometimes taking 5-10 seconds to close. I'd like to figure out why this is, though I'm not quite sure what I'm looking for in the log. I've posted the areas that I think are noteworthy (though I don't really know what I'm looking for) and also attached the full log.
A few other questions I have are related to the things I see in the attached log such as:
"11:19:27.894: [NVIDIA Audio Effects:] NVIDIA denoiser disabled, redistributable not found or could not be loaded.
11:19:27.895: Failed to get NVVideoEffects.dll version info size
11:19:27.895: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded."
There's also a ton of messages related to my new Stream Elements overlays that seem to go on forever so I've shared a small passage of it,
"11:19:29.421: Just Chatting Cam: data.GetDevice failed
11:19:29.421: Just Chatting Cam: Video configuration failed
11:19:29.650: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to load the script 'https://streamelements.com/z/i.js' because it violates the following Content Security Policy directive: "script-src 'none'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
11:19:29.650: (https://streamelements.com/overlay/...7MiucdV7YL7ZX66ggKs0y50GGMCx2qfhHrDrh0lxe4v:0)
11:19:29.900: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'none'". Either the 'unsafe-inline' keyword, a hash ('sha256-fO0h6nSVSg6QGOtEkqzxNcpe9iJLgXxfCBJTJ4butWU='), or a nonce ('nonce-...') is required to enable inline execution.
11:19:29.900: (https://streamelements.com/z/i.js:1)
11:19:29.900: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to execute inline script because it violates the following Content Security Policy directive: "script-src 'none'". Either the 'unsafe-inline' keyword, a hash ('sha256-gTRhbNtQGqUHvXDtmf818c1H/6TlOkaAtc+LAcH0HKA='), or a nonce ('nonce-...') is required to enable inline execution.
11:19:29.900: (https://streamelements.com/overlay/...7MiucdV7YL7ZX66ggKs0y50GGMCx2qfhHrDrh0lxe4v:4)
11:19:29.900: [obs-browser: 'Chat Bubbles'] Error: zaraz is loaded twice (https://streamelements.com/overlay/...7MiucdV7YL7ZX66ggKs0y50GGMCx2qfhHrDrh0lxe4v:4)
11:19:29.900: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to load the script 'https://streamelements.com/overlay/scripts/vendor.js' because it violates the following Content Security Policy directive: "script-src 'none'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
11:19:29.900: (https://streamelements.com/overlay/...7MiucdV7YL7ZX66ggKs0y50GGMCx2qfhHrDrh0lxe4v:0)
11:19:29.901: [obs-browser: 'Socials'] Error: zaraz is loaded twice (https://streamelements.com/overlay/...7MiucdV7YL7ZX66ggKs0y50GGMCx2qfhHrDrh0lxe4v:4)
11:19:29.901: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'none'".
11:19:29.901: (https://streamelements.com/overlay/scripts/vendor.js:47919)
11:19:29.901: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to load the script 'https://streamelements.com/overlay/scripts/app.js' because it violates the following Content Security Policy directive: "script-src 'none'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
11:19:29.901: (https://streamelements.com/overlay/...7MiucdV7YL7ZX66ggKs0y50GGMCx2qfhHrDrh0lxe4v:0)
11:19:29.903: [Vertical Canvas] use user config
11:19:30.118: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'none'".
11:19:30.118: (https://streamelements.com/overlay/scripts/app.js:381)
11:19:30.119: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to evaluate a string as JavaScript because 'unsafe-eval' is not an allowed source of script in the following Content Security Policy directive: "script-src 'none'".
11:19:30.119: (https://streamelements.com/overlay/scripts/app.js:381)
11:19:30.169: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to load the script 'https://ajax.googleapis.com/ajax/libs/webfont/1.6.26/webfont.js' because it violates the following Content Security Policy directive: "script-src 'none'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
11:19:30.169: (https://streamelements.com/overlay/...7MiucdV7YL7ZX66ggKs0y50GGMCx2qfhHrDrh0lxe4v:0)
11:19:30.170: [obs-browser: 'Chat Bubbles'] Error: [Report Only] Refused to load the script 'https://cdnjs.cloudflare.com/ajax/libs/twemoji/2.7.0/twemoji.min.js' because it violates the following Content Security Policy directive: "script-src 'none'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback."
Thanks again for any help!
  • 2025-01-10 11-19-26.txt
