Bug Report OBS loses connection then crashes itself and my game
Trops
Hey guys!
I've seen that a few people are dealing with the same issue as me: I'm streaming and everything seems ok, but OBS loses its connection to Twitch, then it crashes after the stream ending timer and also crashes the game that I'm playing (only tried/happened with CS:GO).
I'm uploading the files from my last stream and also the crash file from last week's stream (same settings).
I'm streaming to Twitch, specially CS:GO, with these settings:
x264
CBR OFF
2000 bitrate/2000 or 3000buffer - 9 Quality Balance
10 seconds as delay set on OBS
1280x720 at 30 fps - Bicubic Sharper
Veryfast
Any other info that may be useful, I'll be more than pleased to post here as we seek for an solution to my problem.
Thanks in advance!
  • OBSCrashLog2016-09-16_1.txt
  • 2016-09-20-1611-36.log
  • 2016-09-20-1632-42.log
  • 2016-09-20-1911-22.log
  • 2016-09-20-1922-55.log
  • 2016-09-20-2141-00.log
Trops
There are 2 more files, if you guys may wanna check as well (post crash)...
  • 2016-09-20-2142-58.log
  • 2016-09-20-2144-57.log
