Bug Report OBS MP 0.8.1 Videodevice configuration crash
Isegrim
0.8.1 crashes every time i try to set the device resolution manuelly. Happens with the 32 as well as the 64 bit version.
I'm useing the amarec extreme cap u3.
  • 2015-02-10 19-25-49.txt
  • 2015-02-10 19-30-17.txt
Meduax
Can confirm the same thing happening with the AverMedia H727 internal capture card. Every time I change the resolution it just crashes immediately. My logs aren't more helpful than the two provided here already either though.
