Question / Help OBS Not Playing Ingame Audio Since Update
David Kelly
I had no issues with audio before I updated it, and I tried turning off the GX setting on my soundcard, which before was the issue when I first started streaming which prevented me from streaming audio on older games, but now its risen again, just its not that anymore
I have provided a log from the last 30 minutes or so of my stream where I had no audio.
  • 2016-09-12-2255-57.log
Harold
Well it may be time to switch to studio.
Especially given that classic hasn't gotten any meaningful updates in over a year.
David Kelly
No because I literally cannot be bothered, and you aren't supplying the answers I want, so I will say it one more time, Stop. Reply. To. This. Post. Please. I'm a lazy and I don't care for your input anymore.
Harold
Too lazy to try stuff that is likely to work because of a wonky piece of hardware.
Ok, got it.
DingoSniper
Ok, got it.
Hey buddy, you ain't helping the situation at all. This is related to the program more so than the hardware. On top of that the issue is more so related to OBS itself or possibly software related, virtual audio cables have absolutely nothing to do with this situation AT ALL.
Unless you are actually going to help fix the issue please fuck off :^)
Harold
AND YET
No portion of the audio capture parts of OBS changed in the update. The asus xonar is KNOWN to be problematic for capturing that is directly related to the issue.
Virtual Audio Cables will give OBS a different angle to attempt to capture the sound from. If you're not going to try them, then chances are the only solution will be to replace the sound hardware you're currently using with hardware known to work properly.
And I figured you didn't want to spend extra money on this.
Excuse me for trying to save you some coffee money.
